Need Help Kyocera 3501i Fwerror code
  • jayar
    • Nov 2022
    • 3
    [Error Code] Need Help Kyocera 3501i Fwerror code
  • rapo_tech
    • Feb 2019
    • 114
    Re: Need Help Kyocera 3501i Fwerror code
    You have to give more info... What was the problem that you updated firmware?
    I have had problems with bad thumbdrive. Try another thumbdrive...
    • jayar
      • Nov 2022
      • 3
      I instaled new SSD onthe machine and its gave me that error when i was trying to install a firmware on new SSD.tnx
      • jayar
        • Nov 2022
        • 3
        btw my thumbdrive is brand new i purchased today..tnx
        • dalewb74
          • Feb 2018
          • 1142
          yeah just because you just purchased a new thumb drive doesn't mean it will work on the kyocera.... certain things have to be done in order for it to work on a kyocera.
          • PrintWhisperer
            • Feb 2018
            • 468
            Here we are again with 'Did you mean HDD or SSD' because the '1' series has no SSD so...yeah I'm going out on a limb and saying he means HDD
            BECAUSE
            Error 0501 (Firmware file preparation error) on OPT (Option Language support) is written to the...HDD!
            Did you format the HDD before attempting a firmware load? MM024 maybe check it out along with MM989 on whatever HDD you put in.
            Is the replacement a Toshiba or Hitachi drive?
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
