KM-C3225 wrinkling paper infuser/exit Sec.
  • JDD
    • 28
    So far I have Repl.Fuser unit - upgraded firmware- lowered fuser speed- still wrinkles intermitant any help thank you
  • cboucher
    • Aug 2025
    Try adjusting Loop Timing. Does this happen from all cassettes or just one? I'm sure you checked this already, but if the paper guides in the cassette are loose or set improperly it will cause the paper to feed crooked and could cause wrinkling as well. Is the image skewed on the wrinkled copies?
      • 23010
      Have you considered a moist paper condition? I would walk in with a ream of fresh paper to test with. =^..^=
      • kyoceradude
        The Great Gazoo
        • Aug 2006
        • 442
        What about the exit section? Are there any toner booggers?
        My mission here on Earth is to help all you Dum-Dums!
        • charly
          • 65
          one of many problems in the fuser unit , chage it
          folds at the trail of paper
          • vikingmita
            • Nov 2008
            • 163
            if humid: plug in heaters in papermags. i'd do that and check if the papermags are aligned correctly, and maybe even pull out the belt unit to check for cracks. since you wrote you'd already changed the fuser, i assume you got a brand new one? old faulty ones made wrinkles at the end of a a4 sheet, and looked even worse on a3. actually several i changed looked just ok on a4, but wrinkled a3.
            • JDD
              • 28
              Don't want to jinx myself BUT!
              I lowered the fuser speed sim. 53 I believe ? raised # from 0 to 16 so far so good
              • SmudgerUK
                • Mar 2008
                • 17
                Have you fitted the modified transfer belt? This has little rollers to help guide the paper through a straighter path.
                Also, if the machine has a finisher it needs to be in a very cool location or plenty of airflow as the finisher can cause the fuser area to overheat causing creasing.
