TA-406ci with recommended fax settings with Verizon Voip issues.
  • copiertec
    • Jan 2016
    • 2211
    We have a TA-406ci (model shouldn't matter) that was faxing good until the customer switched over to Verizon for their phone/fax service. We have followed all of Kyocera's recommendations 1) verified ECM on 2) set V.34 to off 3) TX echo- 500 RX echo - 500 4) lowered TX/RX speed (Baud) to 9600. With those settings the client is still unable to send faxes out to some clients and receive these errors U01094, U01095, U01021.
    Verizon sent over recommended things to do 1) turn off ECM 2) lower baud rate to 9600 and we tried but no success. We are using 2 conductor phone line and tried 4 conductor but it made it worse. Any suggestions?
  • dalewb74
    • Feb 2018
    • 1157
    Re: TA-406ci with recommended fax settings with Verizon Voip issues.
    have you used a butt set to test just the phone line itself?
    • copiertec
      • Jan 2016
      • 2211
      No, I do not know what a butt set is.
      • ntbann
        • Jan 2012
        • 628
        A butt set is a phone like device used for testing and monitoring phone lines. Very useful when working with fax for line static. Also if they have voice messaging sometimes you will get a set of tones before you actually get a dial tone. You will be able to hear that with a butt set.
          • 30313
          Is it going through a surge box or any kind of filter
          • copiertec
            • Jan 2016
            • 2211
            It was, that was the first thing I tried right after Kyocera's recommended settings, I also tried another machine with a fax just to rule out the copier because that's what Verizon started to blame. It was working fine until the customer switched providers and had turned out to be a nightmare for the client, they were promised the sky from the sales person, but Verizon has been MIA since the installation and other issues the client is having, but they are now locked into a contract from what I understand.
            We have basically washed our hands from the issue and have done everything we can think of to correct the issue. We have setup scan to folders and the client is going to email their faxes out at this point until they get a response from Verizon.
            • Samanator
              • Sep 2017
              • 579
              One of the things I always do is to turn off U631 EMC (Error Correction).
              If that doesn't get it and your customer really needs fax, they could try a fax bridge.
              Nextiva vFax (fax bridge) is the one several of my customers have purchased and implemented and it seems to work quite well.
              Heck, I've even set one up for the customer (they bought it, I installed, I billed them).
              Just a thought.
              • copiertec
                • Jan 2016
                • 2211
                Just a thought.
                Thank you, one of the recommendations from Verizon was to turn off the ECM and I tried that as well, I think it made the problem worse, so I turned it back on. Thank you for the fax bridge recommendation, I will look into it.
                • dalewb74
                  • Feb 2018
                  • 1157
                  if at some time i don't have a butt set. i will just use my cellphone and call the customers fax number. and i will listen to the tones, sometimes that is helpful.
                    • 16416
                    Just a thought.
                    All of my phones are thru Nextiva and I have a Fax Bridge. It works flawlessly. But the bridge has to be set up via Nextiva (you must have an account with Nextiva). I had to email them the serial number on the Fax Bridge and a few minutes later it was activated.
                    Nextiva vFAX - How to Set Up a Fax Bridge | Nextiva Support
                      • 37533
                      Buttinskis, butt sets, are nice but unless you do a lot of land line servicing, they are a bit pricey. A Fluke TS19 Telephone Test Set costs over $150.00.
                      Or you can go with a small single line phone for under $20.00.
                      As shown $11.99 at Amazon.
                      • ntbann
                        • Jan 2012
                        • 628
                        Yea they are expensive. Ive had mine since my alarm install days.
                        • copiertec
                          • Jan 2016
                          • 2211
                          I've been called a Buttinski a few times in my lifetime... I had no idea it had to do with checking phone lines. I thought it was a nice way of saying I was an asshole.
