Hi Guys.... I have been using the Kyocera/Mita test chart for 30 plus years, part# 72570140... can't find them anywhere. I am trying to find a good Color test chart also... I have used Precision Roller test chart & have lost them through the years, they don't offer them on their site anymore. I have had the Color test chart from WULFF Enterprises, but I can find them anywhere either. Does anyone have a connection or a lead to where I can buy some color & B/W test charts? Thanks
Looking for Color & B&W test charts
Re: Looking for Color & B&W test charts
Have you considered printing your test patterns from USB? Most digital machines will print PDF's from USB, some HPs only JPGs.
It's a good way to isolate optical defects from print engine defects. What paper sizes do you use usually (largest available paper size will display defects the best)? I've made up test images from 6 3/4 Envelope (6.5" x 3.6") to Drive-In Movie Poster (60" x 40") ... and quite a few in between.
These are the ones that I get the most use of: =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=👍 1 -
Hi Guys.... I have been using the Kyocera/Mita test chart for 30 plus years, part# 72570140... can't find them anywhere. I am trying to find a good Color test chart also... I have used Precision Roller test chart & have lost them through the years, they don't offer them on their site anymore. I have had the Color test chart from WULFF Enterprises, but I can find them anywhere either. Does anyone have a connection or a lead to where I can buy some color & B/W test charts? ThanksComment
... or monochrome?:If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Yes Katun still sell them. P/N 43219 in the UK.
Or as Blackcat says:
Katun Test Pattern.pdfEverything that has a beginning, has an end.....Comment
Thanks guys, yes.. an actual test charge is what I'm looking for, I did order a packet from Katun, a physical test chart on both sides is the answer I was looking for..
Again, I love this site!!!👍 1Comment
These are the ones that I get the most use of: =^..^=👎 4Comment
Did you have any trouble ordering from Katun? Far as i know they moved to Mexico.👎 1Comment
👍 3Comment
No trouble at all ordering from Katun, this post was from way back in 2022. Just curious why you would post something negative on the site? No need to comment like that>>> "Thats the dummbest idea ive ever heard. They will not come out the same as a test chart by the manufacture." NOT NICE!Comment
