Kyocera 5501i - strange noise
  • AlexRust
    • Apr 2014
    • 41
    Hello. Please listen attached sound clip (close to the end) for strange sound. Is anybody can point me in the right direction to fix it.
    Thank you in advance.
    • 23009
    Re: Kyocera 5501i - strange noise
    I sounds to me like the fuser pressure being released, just slightly louder than usual yes, but within normal parameters. If it really bothers you, you can warranty the fuser.
    One other thing ... check the squirrel cage fan for the IH board. It tends to fill up with lint. At full speed its reasonably quiet, but as it slows down you can hear it vibrate. There are other squirrel cage fans in the machine. You can test them individually in U037, if you like. Also try the motors in U030. Usually all it needs is the dust bunny removed.
    • AlexRust
      • Apr 2014
      • 41
      thanks for the tips. Will try them all and report back.
