2 nd paper tray failure
  • JINACHANDRANS
    • Sep 2019
    • 41
    [Error Code] 2 nd paper tray failure
    Hi friends,
    Kyocera taskalfa 3212 shows 2nd paper tray failure. i checkd paper tray clutch and tray mechanicam, every thing is good, even i changed the clutch but not funcioning. is it have any programing. please give the suggestion.
  • kuby
    • Oct 2007
    • 1409
    Re: 2 nd paper tray failure
    Does it just not work, is it disabled, not feeding the paper, shows paper jam?
    • tmaged
      Owner/Service Manager
      • 1888
      Check the error log to see what the code was, run U906.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • subaro
        • Oct 2010
        • 1274
        Most of the time , the tray lift motor is at fault. Check the logs ect as mentioned
