TASKalfa 4012i error code C6400
  • kyove
    • Apr 2015
    • 62
    [Error Code] TASKalfa 4012i error code C6400
    Hi Guys,
    I have a TASKalfa 4012i with C6400 error code.
    I read about zero cross signal but other printers are working well (both colors and bw models), electricity is ok.
    I tryed to change fuser but same error.
    Service manual say to change low power PWB or engine PWB.
    Firmware is up to date!
    Any ideas?
    Someone has already seen this problem?
    Thank you in advance,
    Kyove
    • 16372
    Re: TASKalfa 4012i error code C6400
    Originally posted by kyove
    Hi Guys,
    Any ideas?
    Kyove
    Do you know how zero cross works? Sine wave?
    The heaters are turned on only when the voltage is zero. This minimizes power draw. Your problem most likely is with the power source.
      • 30088
      Did you reset the fuser code?
      Pretty rare boards fail on Kyocera machines
        • 16372
        PS - You said other printers were working with no problem but are they on the same circuit? What have you done to test the power source? Sometimes it's hard to track down a power source problem. It could be happening only at a certain time of day? Or when another piece of equipment is powered on?
          • 23003
          +1
          How did you decide that the power is OK? =^..^=
          • kyove
            • Apr 2015
            • 62
            @BlackCat:
            Machine gives the same error both at the customer's site and at my site.
            @BSM2:
            There is no U163 on this model.
            Is possible to repair PWB instead of replace it?
            Maybe a common problem like a opto-isolator or something like that.
            • subaro
              • Oct 2010
              • 1274
              @BlackCat:
              @BSM2:
              service mode 906 reset.
                • 16372
                @BlackCat:
                Probably not. I just priced this board repair @ Hy Tech. This cost is around $250.00.
                  • 30088
                  When does the code happen? Bootup
                  Reseat all connections on onboards
                  Was a service call preformed before this started?
                  If so what was done
                  • kyove
                    • Apr 2015
                    • 62
                    Tryed U906 - no luck.
                    Tryed U287 - autorecovery on error C6xxx - no luck.
                    Error come up on boot. After powering up with the main switch, machine motors turns for a short time, DP make its selftest and then - four beeps - error code C6400
                    I'm ordering a PARTS UNIT LOW VOLTAGE 200 SP
                    • PrintWhisperer
                      • Feb 2018
                      • 468
                      I have seen a zero-cross error only once, it was due to cold solder joints on the Power Supply.
                      Zero cross monitors the frequency of the AC sine wave by measuring the rate at which the wave crosses the zero volt line.
                      Changes in frequency will alter the voltage applied to the circuit and hence the power produced, possibly creating a dangerous situation.
                      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                      • MarcoKyo
                        • Nov 2019
                        • 9
                        Hello,
                        Also check the connector between fuser and main unit.
                        Good luck
                        • kyove
                          • Apr 2015
                          • 62
                          Hi Guys,
                          Replaced 302RH94230 - PARTS UNIT LOW VOLTAGE 200 SP, problem is solved.
                          Thank you all!!
                          Kyove
