TA 4002i DP 7120 Not stacking while stapling... Paper ?
  • Doug James
    • Jan 2012
    • 935
    I delivered a finisher to a customer that workedf well in my shop then delivered and now won't staple because it won't pull paper in evenly. I delivered another (exact same) finisher and has the same issue. They are using Quill paper. Does cheap paper make a difference with these. There was a time that paper was a taboo excuse. So what is happening Thanks so much for any response !!!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: TA 4002i DP 7120 Not stacking while stapling... Paper ?
    There are gray rubber paddles that pull the paper back in. The edge is square when new & gets worn down. If you don't have new ones, you can flip them over. They're relatively easy to unclip if you remove the finisher top cover.
    https://www.copytechnet.com/forums/k...isher+stacking
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
