Kyocera M3040idn feed clutch assy?
  • copykat93
    • Oct 2021
    • 281
    Hi Guys, I have the service & parts manual, but I can decipher what part I need for the primary feed clutch for drawer 1... I have an M3040idn that I can watch the feed roller & shaft kind of stall out, like as if the clutch is slipping while it is trying to feed paper. I thought it would be easy enough to order the clutch for the top drawer, but there really isn't a clear picture of what I need and what part number to order. Has anyone replaced the clutches? I removed the side covers & it looks like it is an entire assy, or can I just replace the clutch for drawer 1? By the way, the machine only has 125K on the meter, I have done the feed rollers & drawer sep assy, but once I saw the feed stall & slip as it's feeding by watching it from the rear, I would presume it needs the feed clutch.
    UPDATE:::
    I actually removed the clutch pack & cleaned the primary clutch up & am going to reinstall to see if it helped.
  • CWP
    • Jun 2013
    • 168
    Re: Kyocera M3040idn feed clutch assy?
    Parts manual shows it as:
    302MS94051
    PARTS DRIVE FEED ASSY SP
    40ppm(A4),42ppm(Letter)(A)/40ppm(A4),42ppm(Letter)(AF)/
    • copykat93
      • Oct 2021
      • 281
      Yes sir... Thats it... I actually found it after I posted... I also tried to clean assy & it made it worse.. I guess I will order the drive feed assy. Thanks CWP
        • 23010
        Did you see any rust dust? =^..^=
        • copykat93
          • Oct 2021
          • 281
          YES!!!... I sure did... I then went to my copier boneyard and found a pretty low meter (under 200K) M3550idn & I stole the primary feed clutch out of that assy & put it in the M3040 assy & I ran over 200 pages without a jam. I couldn't get more than 20 & it would start to get weak and the clutch would slip. The 3550 clutch did the job & it works really well.
            • 23010
            Congratulations on your success!
            I haven't had much luck with cleaning the Daiken branded clutches. =^..^=
