Kyocera FS-C8520MFP UPPER CASSETTE NOT LIFTING SERVICE CODE:01.7620 EVENT:0501 & 0511
  • chinotech
    • 14
    [Error Code] Kyocera FS-C8520MFP UPPER CASSETTE NOT LIFTING SERVICE CODE:01.7620 EVENT:0501 & 0511
    Hello Experts:I have a problem with a FS-8520MFP not lifting tray 1. Tray 2 and MP tray work fine. Cassette from tray 2 works in tray 1 position. No motor sound at all. Manually pressed tray switches and no reaction. Tray 2 lift motor activates as soon as I press any tray switch. Is there a reset for tray 1 lift mechanism? I suspect lift motor, but I didn't see a motor test for tray 1 in the service manual (unless I am missing something). I hope someone has experienced a similar problem and can help with a suggestion-I admit I am not a Kyocera guru, but I have over 30 years in the business. Thank you!!!
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Kyocera FS-C8520MFP UPPER CASSETTE NOT LIFTING SERVICE CODE:01.7620 EVENT:0501 &
    Yes there is. It is in the system menu. I think it is called something about "reset repaired something"
    • davidmtupper
      • Jul 2021
      • 326
      U906 on most Kyocera copiers
        • 23009
        In this case tonerkiller is correct. The Hanabi is an exception to the rule:
        Run reset disable function (Enable Repaired Unit will only appear if there is a disabled unit to reset): Run reset disable function: System Menu/Counter > ^/v to Adjustment/Maint. > ^/v to Service Setting > ^/v to Enable Repaired Unit > Start.
        • chinotech
          • 14
          Thanks for the quick responses! I will head back and let you know how it goes.
