Void areas when scanning on a CS5054ci
  • Submairnergold
    • Apr 2022
    • 3
    Got a Customer with a new machine that is having problems when scanning IRS forms saying that they are getting void areas no problem with other doc's. Want to know if anyone else has had this problem
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    Re: Void areas when scanning on a CS5054ci
    It doesn't sound like a hardware issue, if other docs aren't doing it. Possibly counterfeit protection, although that usually locks up the machine.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Submairnergold
      • Apr 2022
      • 3
      Thanks for the reply that's perty much what tech support said just wanted everyone else's thoughts.
      • PrintWhisperer
        • Feb 2018
        • 471
        Try reduction beyond the 1% the hotline recommended. Increase the reduction until you pass the detection algorithm. In the past this has worked, but there may be new parameters in the '4' series algorithms
        In the past, the counterfeit system has generated a code, or displayed a message. There has been behavior of 'greying-out', but this voiding seems to be a new method.
        Be sure to supply sample of the form and output examples if you cannot get past it via reduction.
        Certainly BW mode should be used as well.
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • toddanderson
          • Dec 2005
          • 236
          Post some samples of the issue
