KM 3050 fax problem
  • nodle
    • 142
    KM 3050 fax problem
    We are hoping that someone has run into this issue and can provide us with some insight as to solution. We have a KM3050i that when faxing a letter size document is turning the image sideways for the person receiving the document so it is extremely reduced and it also shows it being sideways on the fax confirmation that is printed out on the machine. The only suggestion we have gotten thus far from DSC is to replace the HHD which we have done twice now one a repaired HHD and the second time one direct from the vendor.
    Any help will be greatly appreciated.
  • totoro
    • 568
    Check the width and lenth sensors in the doc feeder.
    Totoro
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1885
      I'd try faxing one from the glass. This should point you to the ADF. Usually when the receiving fax reduces, it's because it thinks it's receiving a ledger size document.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 23008
        I agree with both respondents. Most likely the document feeder is mis-identifying the original length as ledger, not letter. As a result the ledger size original is reduced and rotated to fit.
        The best way to confirm this is to fax from the contact glass. If the image is correctly identified as letter, then it is definitely a DP sensor problem.
        On a side note this should affect all scanning functions: copying, faxing, and scanning. =^..^=
