ECOSYS M2535dn NW-Fax driver WIN10/WIN11
  • taskalfa
    • Jun 2011
    • 97
  • copiertec
    • Jan 2016
    • 2211
    Re: ECOSYS M2535dn NW-Fax driver WIN10/WIN11
    I believe Kyocera just came out with a new fax driver to address these issues ver. 7.2.1403
    • Swift
      • Apr 2011
      • 29
      Having similar issue on Fax driver v7.2.1403
      • PrintWhisperer
        • Feb 2018
        • 473
        Seems related to the fact that most drivers from Kyocera are unsigned (it costs for every version, every update). The current referenced update is for new models.
        Driver Signing - Windows drivers | Microsoft Learn
        Starting with Windows 10, version 1607, Windows will not load any new kernel-mode drivers which are not signed by the Dev Portal.
        You might check the OS version for applicability and the setting found in 'Method 2' here:
        How to disable Driver Signature Enforcement in Windows 11?
        'Method 1' seems risky, I have not tried either.
        I am not clear if it only disables the message or if it allows the kernel-mode drivers to install regardless.
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • taskalfa
          • Jun 2011
          • 97
          This is what fixed our issue
          The occurs when visual c+ + (vcredist_86.exe) is not installed on the desktop, this is a requirement for the OpenSSL used by the NW Fax driver to work.
          • rpep
            • Apr 2023
            • 1
            What I just found is that you have to instill the xps driver then the NW Fax driver. Apparently the needed libraries for the FAX are not contained in the KX package.
            • KenCurtis
              • Nov 2023
              • 4
              I have tried the ideas posted here , but I am still having the issue on a workstation.
              Are there any other ideas for a Win10 install
              • berkay956
                • Nov 2023
                • 2
                same error for my work pc windows 11. I tried everything but nothing changed, I hope kyocera will solve it...
