ECOSYS M2535dn NW-Fax driver WIN10/WIN11
Re: ECOSYS M2535dn NW-Fax driver WIN10/WIN11
Seems related to the fact that most drivers from Kyocera are unsigned (it costs for every version, every update). The current referenced update is for new models.
Driver Signing - Windows drivers | Microsoft Learn
Starting with Windows 10, version 1607, Windows will not load any new kernel-mode drivers which are not signed by the Dev Portal.
You might check the OS version for applicability and the setting found in 'Method 2' here:
How to disable Driver Signature Enforcement in Windows 11?
'Method 1' seems risky, I have not tried either.
I am not clear if it only disables the message or if it allows the kernel-mode drivers to install regardless."Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
