Task alpha 306ci reboots itself.
  • armandohg
    • Feb 2021
    • 1
    Hello good vening.
    I have a Task alfa 306ci, it reboots itself constantly.
    I already installed a voltage regulator, updated the firmware and it keeps rebooting.
    I printed the event sheet and the last errors that appear are c7611 and c 7620. Clean the transfer belt and the density sensors.
    Thanks for your help.
  • GIUBOSS
    • 1437
    Re: Task alpha 306ci reboots itself.
    Originally posted by armandohg
    Hello good vening.
    Have you also tried checking/cleaning the primary transfer belt section, id sensors, etc... following the service manual?
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1898
      In the past, print jobs have caused this phenomenon. I would disconnect the network cable to see if it persists.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
