Maintenance Mode U0906 (Resetting the partial operation)
  • Copier Mechanic
    • Mar 2023
    • 89
    Hello Guys,
    What exactly does U0906 do? Does it disable something on the copier? Please someone explain what is the purpose of this mode. Thanks in advance!!
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1894
    Re: Maintenance Mode U0906 (Resetting the partial operation)
    It's to re-enable functions that have been disabled do to a failure. Cassette lift error, finisher motor errors, etc.
    You should see a corresponding error for the disabled function in the log to let you know where to begin troubleshooting.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23010
      Depending on the model of Kyocera, U906 can reset certain error conditions (does not affect paper jam conditions). Certain models of Kyocera (specifically Matsuri) do not use U906. These models have a menu item that appears in the System Menu when an error condition occurs, which allows you to reset the error. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        <-- the guy who replaced nearly every finisher component not knowing that.
        Thankfully it was an inner finisher so just a board, elevation motor and a sensor or two.
          • 16455
          Think of it as kinda like rebooting your computer.
            • 23010
            At one point I had started down that road, but accidentally browsed past the correct page in the manual.
            So many of my successes were entirely based on dumb luck (and perhaps a bit of stubborn persistence).
            • Thorsten_300ci
              • May 2018
              • 15
                • 23010
                Which error?
                So after you perform the U906 partial reset, have you monitored the lift motor voltage to see if the lift motor is getting voltage? =^..^=
                  • 16455
                  Luck. I think not. Not with you. You're the type of tech that creates his own luck with persistence, dedication and an unmatched work ethic.
