Kyocera Copy Star 300 scan function - Windows 11
    • 30228
    #16
    Re: Kyocera Copy Star 300 scan function - Windows 11
    the old version of filezilla
      • 30228
      #17
        • 30228
        #18
        Originally posted by Karen
        Thank you. I will try it. Worst case scenario I have an old laptop with Windows 8. I can (hopefully) set it up to scan to that, drop it to a flash drive, and load it to the Windows 11 computer. Not buying a new copies (she says). Tried to update the software to the copier through KM NET. That failed. Sigh.
        update firmware with flash drive
        • Karen
          • Apr 2023
          • 16
          #19
          I don't believe the machine has a USB. But it does have an ethernet port. Can I download the firmware to a computer and connect the computer to the copier/printer and update that way?
          • Karen
            • Apr 2023
            • 16
            #20
            FTP is difference port 21 old fall back when smb was an issue
            I will try it. The instructions are basically the same, except the folder is not shared.
              • 30228
              #21
              Only with km net viewer
              • Karen
                • Apr 2023
                • 16
                #22
                I'm going to try Filezilla a soon as I can take over my secretary's computer. I'll let you know!
                  • 30228
                  #23
                  Don't forget to open the firewall windows always blocks it
                  • Karen
                    • Apr 2023
                    • 16
                    #24
                    I have McAfee. Firewall if off. But I'll double check.
                    • Karen
                      • Apr 2023
                      • 16
                      #25
                      I had to buy the manual ($4.99) and give my secretary's computer back. Some of the set up exceeds my knowledge. It is installed, now I have to configure it. I did allow if through the Windows Firewall. It is on but managed by McAfee.
                      • Karen
                        • Apr 2023
                        • 16
                        #26
                        Thanks to everyone for all of your help! I cannot tell you how much I appreciate it! I was able to download FileZilla but setting it up exceeds my abilities. Even after I purchased the manual for $4.99. I will hire someone to set it up for me. Better than buying a new copier / scanner!
                        Any suggestions on what type of service I would look for? I am a business owner, somewhat tech savvy, but technology keeps getting more and more complicated. Until now, I have been my technical support.
                        I am located in Southern California, Riverside County.
                          • 30228
                          #27
                          Someone should be able to setup via remote as long as they can web in an configure filezilla
                          watch both videos again the only password you need is for the user
                          the path for the copier should be either the host or hard ipaddress path is a .
                          good luck
                          • tmaged
                            Owner/Service Manager
                            • Oct 2008
                            • 1885
                            #28
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            Become a fan on Facebook
                            • Karen
                              • Apr 2023
                              • 16
                              #29
                              good luck
                              Yeah, I need help with that!
                              • Karen
                                • Apr 2023
                                • 16
                                #30
                                I have a service contract with a copier company, I will contact them and see if they have someone, or can refer me!
