Kyocera Copy Star 300 scan function - Windows 11
  • Karen
    • Apr 2023
    • 16
    I have a Kyocera CS 300. I just purchased new computers and I am trying to set up the scan to shared folder (SMB) function, which I have set up on my old computers. When I try to log into the IP address 192.168.1.5 "Unsupported protocol -The client and server don't support a common SSL protocol version or cipher suite."
    So, I tried to configure it manually by going to send, and entering the data manually, which includes the Host Name (name of computer), Path (location of shared file), Login user name (email - same on in the old computer), and login Password (same one I had in the old computer) and it cannot connect.
    Any help would be greatly appreciated!
    • 30253
    Re: Kyocera Copy Star 300 scan function - Windows 11
      • 30253
      You may get web page error usually go to advance than continue to web page
        • 16395
        What browser are you using? Try running an older version of Internet Explorer...if it's still supported.
        • Karen
          • Apr 2023
          • 16
          Unfortunately, it just closes the window down. It doesn't give me any advanced options.
            • 16395
            That's because Sha2 and and TLS 1.2 aren't enabled. You will have to use an older browser in order to log in to the Kyocera webpage.
              • 30253
              Try chrome
              • Karen
                • Apr 2023
                • 16
                Try chrome
                I did. I tried Chrome, Edge and the unsupported Internet Explorer. I also ran a Google search to see if there was some setting in Windows 11 I could go into and change. I found nothing. I have the Kyocera book, but I own the machine and they are not helpful.
                • Karen
                  • Apr 2023
                  • 16
                  I did. I will try Firefox. Tomorrow.
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1887
                    You can download older versions of Firefox and disable updates. Directory Listing: /pub/firefox/releases/
                    I'm running 90.0.2 for this very purpose.
                    I don't believe the 300i will support the SMB version needed for Windows 11 though.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • Karen
                      • Apr 2023
                      • 16
                      I used the Internet Explorer on the remaining computer I have Windows 10 on. I have an older laptop that I will try tomorrow.
                      • Karen
                        • Apr 2023
                        • 16
                        Thank you. I will try it. Worst case scenario I have an old laptop with Windows 8. I can (hopefully) set it up to scan to that, drop it to a flash drive, and load it to the Windows 11 computer. Not buying a new copies (she says). Tried to update the software to the copier through KM NET. That failed. Sigh.
                        • tmaged
                          • Oct 2008
                          • 1887
                          FTP is always an option.
                          Hope that helps !
                          -Tony
                          www.dtios.com
                          • Karen
                            • Apr 2023
                            • 16
                            What is the setup difference? It seemed to be the same to me.
                              • 30253
                              FTP is difference port 21 old fall back when smb was an issue
