Kyocera 4501i accounting track problem
  • COPIERMAN
    • Jun 2009
    • 559
    they have had copier for two years no problem printing. they turn on tracking everything works but every couple of days a print job hangs up. IT personal goes in removes print job and everything goes back to normal and works properly and then happens a again. Somes its is a word document / PDF / web page. just says printing but never finish job. Has anybody had a similar issue
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1889
    Re: Kyocera 4501i accounting track problem
    If the job accounting was the issue, you'd get an invalid ID error. If you think it is related, you could allow unknown jobs to print.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 30310
      Could be a font problem update the print driver and firmware
      Wrong code would just delete the job
      • ntbann
        • Jan 2012
        • 628
        Also if there is old and new drivers on the same pc will cause havoc with account control.
