KFS through a firewall
  • copytech_32716
    • Nov 2022
    • 21
    I have a client that added a new firewall and all his machines dropped offline in KFS.
    I sent them the Tech Bulletin #12 POST data
    and they added the rules.
    The diagnostic tool on the DRD Tool has all green checkmarks and they said "They can see traffic leaving the firewall headed for the XMPP servers"
    Any other ideas?
    • 30236
    Re: KFS through a firewall
    Reboot devices and firewall
    • tmaged
      Owner/Service Manager
      • 1887
      Enable the browser on the mfp & see if you can get to https://rfs-us.kyocera.biz/
      It should show OK on the browser.
      Also check that Geo Blocking isn't on. The KFS servers aren't located in the US.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • copytech_32716
        • Nov 2022
        • 21
        Do you know what country to allow? They say all the servers are in Texas...
        • Samanator
          • Sep 2017
          • 579
          Some would say Texas is another country, but that is probably a discussion for another time......just sayin'.
          • tmaged
            • 1887
            The Whitepaper says the servers are located in the EU, Amsterdam & The Netherlands. I'm assuming the servers will stay the same when they switch from the XMPP protocol.
            Hope that helps !
            -Tony
            www.dtios.com
            • sparkycivic
              • Apr 2017
              • 348
              Have the firewall admin ENSURE that TLS/SSL inspection be DISABLED for traffic to/from these devices. If they can't prove that the traffic is unmolested, have them create a firewall rule/policy that DMZ's the devices as a test to prove that their firewall is the problem, because it is always the firewall.
