Kyocera TASKalfa 351ci Dots / Lines
  • Medical-Deal
    • Apr 2023
    • 6
    Hi, i have several dots lines on my printings, any suggestion what parts responsible for that? check the attachment and thanks in advance!kyoScan-‎4‎.‎25‎.‎2023-‎17‎.‎01‎.‎31.pdf
    • 16391
    Re: Kyocera TASKalfa 351ci Dots / Lines
    It's a probable PCR but what's the distance between dots? Are you familiar with the repetitive defects chart in the manual?
    • Medical-Deal
      • Apr 2023
      • 6
      Iam not familiar with repetitive defects chart because i cant find it and its not in the manual, the distance is approx 100mm!
      • ntbann
        • Jan 2012
        • 628
        Repetitive defect is usually in the appendix of the manual.
          • 23008
          Originally posted by Medical-Deal
          Hi, i have several dots lines on my printings, any suggestion what parts responsible for that? check the attachment and thanks in advance![ATTACH]57954[/ATTACH]
          I believe the term for this is called: striction
          The drum has a clearcoat that prevents toner from sticking to it ... or it used to have a clearcoat until it wore off in some places. When that clearcoat is worn off toner sticks in those areas, and does not clean off of the drum surface. It can probably be scrubbed off with the right chemical cleaner, but will continue to re-occur in the same areas frequently until the drum is replaced. Chemical cleaning removes even more of the clearcoat, accelerating this process.
          It might be pertinent to know how many images were made with this drum. =^..^=
          • Ropariva
            • 674
            Replace drum with DK-5140a. These were modified to prevent the marks you are seeing on the drum caused by the blade.
