Compressed blurry print near trailing edge each page Kyocera 420
  • jonsimmons
    • Apr 2019
    • 2
    [CQ] Compressed blurry print near trailing edge each page Kyocera 420
    Kyocera 420 with 700k (!)
    Any ideas what is happening here?
    There is a stripe of blurry compressed print, top to bottom (across), 1 1/2 inch from the trailing edge. That is exactly where the leading edge hits the delivery/exit rollers while the paper is touching the drum.
    • I have replaced feed rollers and registration roller asm
    • cleaned sensors with air
    • tinkered with the paper loop, delivery motor speeds, separation charges
    • Checked drum gear is secure and not slipping
    ...trying to post a pic, but not working
  • darry1322
    • Oct 2010
    • 817
    Re: Compressed blurry print near trailing edge each page Kyocera 420
    Broken and/or missing pressure spring/holder on one side of the transfer roller.
    • jonsimmons
      • Apr 2019
      • 2
      Good call. That was the initial problem. The holder was broken so I replaced both, but CQ issue the same. I should probably replace the roller and springs, too.
      • kjg
        • Mar 2009
        • 111
        Usually TR and/or Drum entrance guide. the one that comes in the maint kit.
