7002i / 8002i development unit problem
  • amazed
    • 17
    Hi! We have 7002i and 8002i in one location and 7002i in another location and all of the machines have the same problem.
    The new development unit (or new MK) works pretty well until 30-50k copies, then toner dust starts to collect on development unit (and make toner spills on paper)
    we checked the toner dust "suction" system and filter unit on the rear side (even tried to remove filters), everything works and ther is no clogged toner in it
    we also vacuumed development unit, but this operation helps for another 10-15k copies. Toner is OEM.
    Any suggestions will be highly appreciated.
  • Ropariva
    • 703
    • copiertec
      • Jan 2016
      • 2211
      Re: 7002i / 8002i development unit problem
      • Ropariva
        • 703
        I can tell you the counters max out at 9,999,999. Extremely clean and reliable machines.
        Sent from my iPad using Tapatalk
        • amazed
          • 17
          genuine original kyocera toner
          Originally posted by Ropariva
          Are you vacuuming out the passage between the developer and the dust extractor filter unit?
          Yes, each time, even tried to remove filters to increase air flow.
          • Ropariva
            • 703
            • amazed
              • 17
              Today cleaned up everything again and removed on 8002 toner filter (the fan runs with no problems), registration roller dust pad is clean.
              on mk replacement following is done: 119-140-127-464-412-464-410-251
              Will be back soon with result (quantity of printed pages and fotos of units)
              • toddanderson
                • Dec 2005
                • 238
                did you vacuum the ducts on the machine inside frame, that the developing unit mates to
                • KYO_OEM
                  • Aug 2011
                  • 728
                  i have had same issue and asked KDC tech for help.
                  take a look for the enclosed file and follow up the complete cleaning procedure at first.
                  (i am not able to read japanese, so i got translated version)
                  i would asked for data, but in cleaning in the right way solved the problem.
                  To prevent further problems, i prefer to check/ clean all points each 300.000 pages.
                  • Ropariva
                    • 703
                    Yep, those ducts absolutely need to be vacuumed each MK or at Mini PM 300k if required. 8001s were terrible for clogging this, 8002/3 so much better.
                    • copiertec
                      • Jan 2016
                      • 2211
                      We always had problems with the fusers not making it to 300k on the 8001's (Zeus II) seems the pressure release motor would fail constantly, but we had no issues with the 3501/5001(Alfard II) fusers and the pressure release motors though.
                      • Ropariva
                        • 703
                        Never had those issues but all ours were high volume. Do you turn silent mode on?
                        • copiertec
                          • Jan 2016
                          • 2211
                          I don't think so from what I remember, but I'm sure it would have helped. We started putting all machines on silent mode since the '02 series because of fuser issues.
