KYOCERA 10871087
  • konicatoshiba
    • Jan 2023
    • 32
    KYOCERA 10871087
    Kyocera 4012i can't login 10871087, please help,Thanks all!
  • allan
    RTFM!!
    • 5462
    Re: KYOCERA 10871087
    What is displayed on the screen? Any errors or messages?
    Whatever
    • kuby
      • Oct 2007
      • 1396
      Try 4000/4000 with the web interface.
        • 30061
        Open the front or side cover then try
        • green4go
          • Jan 2022
          • 51
          Are you trying to get to Service mode or the System menu?
          if you are trying to get to service modes - try "status" button then 10871087.
          if you are trying to get to System menu - try either UN: 4000, PW:4000 if it's a TaskAlfa or i think on this model it might be an Ecosys so try UN: 1200, PW: 1200
          Good Luck
          • toddanderson
            • Dec 2005
            • 235
            Was it changed to something different, A lot of dealer are changing it to something other, because of security reasons
            • Step
              Senior Technician
              • Sep 2015
              • 42
              I do not think you can change the maintenance entry code.
              You can change the system user and password yes.
              Make sure you do not have any sticky buttons that interfere when trying to access maintenance mode. Most of the time it's sticky button.
              Sent from my SM-A736B using Tapatalk
              • Gab
                • Aug 2015
                • 671
                Some of the buttons don't work well or (if the numbers appear on screan ) select the buttons faster
                • clacico
                  • Nov 2012
                  • 5
                  In these multifunctions it is possible to change the 1087 with Simulation U010.
                  If changed, it is no longer possible to "go back".
                  • yakyitz
                    • 245
                    Kyocera tech reps can get into the maintenance mode with their secret codes and reset it.
                      • 37431
                      Man that code is ancient. It is from before digital.
                      We used to have an administer who used that as his handle.
                      • dalewb74
                        • Feb 2018
                        • 1142
                        ummmm there is another code besides the one you are using. but any of the codes shouldn't be made public. its very simple if you are a kyocera tech... just a series of numbers different from the ones you entered.
                        • KYO_OEM
                          • Aug 2011
                          • 711
                          if any other job is still waiting in the internal queue you don`t get access to 1087
                          open "Status", delete all visible jobs and try again.
                          Otherwise you has to ask KYO for special entrance code.
                          KDC can prepare 1 time entrance code for this serial number to get access.
                          See enclosed my own created leaflet for our customer techs.
                          • konicatoshiba
                            • Jan 2023
                            • 32
                            Thanks you,i need usb fw,cant you help me.
                            • KYO_OEM
                              • Aug 2011
                              • 711
