Taskalfa 8353ci and DF7110
  • Elmo
    • Feb 2010
    • 541
    Hi
    According to the Brochure the DF7110 finisher should work
    are there any specific brackets i would need or will the standard 1s fit ?
    would anyone have the a copy of the install instructions or possibly the service manual
    i have 2 spare DF7110's i would like to fit 1
    I Used To Live To Fix Things Now i Fix Things To Live
  • kuby
    • Oct 2007
    • 1410
    Re: Taskalfa 8353ci and DF7110
    If you have a service manual it is in there. But send me your email address and I will send you the installation manual.
    • Ropariva
      • 693
      • KYO_OEM
        • Aug 2011
        • 725
        see attachment
        • JohnC_EDP
          • Apr 2023
          • 5
          No AK kit needed on these models. bridge unit comes standards.
          • sparkycivic
            • Apr 2017
            • 348
            8353ci already has "attachment kit" by default.
            Make sure the plastic flap is installed at the upper paper exit so that sheets destined for "output tray C" cannot fall into the gap between the finisher and the copier body.
            DF-7110 will need the metal plate/electrical connector unit which screws to the body of the copier with 2 long screws.
            New DF-7110 comes supplied with this plate and all necessary screws.
            • Elmo
              • Feb 2010
              • 541
              Thank you all for the advise all sorted now
