ECOSYS M5526cdw, staines
  • Hansoon
    • Sep 2007
    • 3360
    I am a KonicaMinolta guy with not too much experience with Kyo's and I see this machine for the first time.
    It is making two fat lines with stains. This seems to be a known issue with these machines and according to sources it needs a new Transfer Belt Unit as well in most cases also a new modified waste toner auger.
    Is this still correct? Any modifications to avoid this issue in the future?
    Does one have for me please the part # for the necessary parts and
    a technical manual?
    Some additional advice or hints, please?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • KYO_OEM
    • Aug 2011
    • 705
    Re: ECOSYS M5526cdw, staines
    Belts would modified by KDC
    Check waste forwarding spring in bk drum.
    If spring not deformed, new belt needed only, otherwise new drum bk + belt
      • 855
      Take a look at the charge rollers they tent to get coated with paper dust . Clean them that will save you a call later
      • Hansoon
        • Sep 2007
        • 3360
        Do you have for me the part#'s please?
        Hans
        • KYO_OEM
          • Aug 2011
          • 705
          here you get the bulletins
          Take care for it and decide by yourself what`s needed for your case.
          • Hansoon
            • Sep 2007
            • 3360
            Anyone having for me the service manual, please?
            Hans
            • OlliK1969
              • Nov 2016
              • 310
              Hi
              Is it possible to get just the cleaning unit separately or does the whole transfer unit have to be replaced?? I have a device that is just 2 years old, has only printed 2,500 pages and now the error has occurred. Thanks for an answer.
              • KYO_OEM
                • Aug 2011
                • 705
                from KDDE you get 3 years of warranty for the belt unit, it`s LLU part and:
                "NO", cleaning unit itselfs it`s not available as a separate sparepart.
                Get in touch with Meerbusch and send warranty claim for broken one after you ordered/ mounted new part.
                • ricohmaina
                  • Dec 2011
                  • 20
                  I think Its a bad design or at least the firmware should be updated to run the waste motor longer to prevent the clogging up of waste and paper dust.
                  I clean out the packed solidified toner from the waste assembly. Then I drill a hole through shoulder side of the gear, inside toward the waste assembly. Add a piece of a fatter paper clip and bend both ends over. basically just reconnecting the gear to the auger because the outside lock on the gear is destroyed.
                  I've had pretty good luck with this field fix, unless its do for a black drum.
                  • Hansoon
                    • Sep 2007
                    • 3360
                    I cleared the lumps of toner out of the assembly and made a repair of the damaged D-shaped white gear and everything seems fine now.
                    Is there a known reason for the waste toner coming from the transfer belt clogging the transport coil? The machine I have now in my workshop is just one year old and made only 5K prints. Based on the modified longer "Waste Toner Lump Breaking Spring" one would not be expecting this problem coming up again.
                    Hans
                    • ricohmaina
                      • Dec 2011
                      • 20
                      It will happen again and again. The ones that I repaired have been successful but then the black drum backs up from the waste toner and in turn packs the waste assembly.
                      • OlliK1969
                        • Nov 2016
                        • 310
