Kyocera 3212i error F040
  • konicatoshiba
    • Jan 2023
    • 33
    Kyocera 3212i error F040 how to fix it
  • dalewb74
    • Feb 2018
    • 1167
    Re: Kyocera 3212i error F040
    describe what you have done to fix it.... this isn't a free we fix your problems for you website...
      • 30570
      Update to the lastest kx driver
      It may need firmware to correct the issue
        • 16555
        Engine PWB communication error. Check all the connections on the board, including the cable between the 2 boards. If all else fails, replace the Engine PWB.
          • 920
          Agree with Billy . If that unit has a flat cable my guess would be thats not plugged in good
          • KYO_OEM
            • Aug 2011
            • 729
            never ever run FW upgrade in case of F040/ F041!!!!
            System will stuck in fw upgrade procedure!
            I do not know the exact wiring between mpt and engine pwb at the moment, but i have had several F040 calls on Jupiter series because of broken wiring from mpt size switch.
            Disconnect VC16 on engine pwb and run reboot for checking.
            >>no more F040 > check wrining all the way in, mostly it breaks inside from mpt hinge
            >> still F040 unplug all components from engine pwb without power supply and communication main<-->engine
            >> reconnect step by step until F040 is coming up again
              • 16555
              [ATTACH=CONFIG]59157[/ATTACH]
              Good stuff, KYO.
              • konicatoshiba
                • Jan 2023
                • 33
                THANKS YOU,I TRY
                • konicatoshiba
                  • Jan 2023
                  • 33
                  Originally posted by konicatoshiba
                  THANKS YOU,I TRY
                  hi
                  • KYO_OEM
                    • Aug 2011
                    • 729
                    By the hell, never ever seen this kind of c-call history
                    something breaks down your main <-->engine pwb communication circuit i think
                    C0060>wrong main firmware on ssd card/ no match with engine eeprom> connected to hidden sub pwb
                    CF040>No communication with engine pwb
                    CF041>no communcation with scanner asic> connected to engine> connected to DP
                    C3800>no communication with CCD unit> connected to engine
                    C0180>no serialnumber> no communication with eeprom on engine pwb
                    That`s all related to engine controlling and/ or no communication between both pwbs
                    Reconnect ALL connectors on main and engine pwb
                    Because of this less counter, i do not think that`s related to mpt wiring.
                    • konicatoshiba
                      • Jan 2023
                      • 33
                      kyocera 3212i still works but when sleeping after 2 hours, the machine will appear error f040, I have not found the cause, thanks!can you help me.
                      Mở tro
                      • KYO_OEM
                        • Aug 2011
                        • 729
                        take care for U346 and change from more energy save mode to less energy save mode + set auto sleep to OFF.
                        the system will not sleep so deep after changing
                        It was also helpfull in past against F040 on other systems after coming up from energy save mode.
                        Also newest FW can be helpfull.
                        • konicatoshiba
                          • Jan 2023
                          • 33
                          HI,THANKS YOU.,I TRY
                            • 30570
                            MAIN 2V6_2000.002.112 002.112 Updated
                            MMI 2V6_7000.002.022 002.022
                            PANEL MAIN 2ND_7200.001.016 001.016 Updated
                            current level firmware
                            • konicatoshiba
                              • Jan 2023
                              • 33
                              I need firmware to repair it,can you sent my inbox,thanks you very much!
