Kyocera M6235cidn... Auto shut off function?
  • copykat93
    • Oct 2021
    • 281
    Hi Guys, As I'm sure you all know the history with this machine and the dash marks on the (K) black drum unit.. Is there a way for this machine to auto shut completely off after a certain time, I know I can set the energy saver time & sleep time... But I would like to be able to have this model shut completely off after a certain time... I have customers who are good with the 2 or 3 min sleep/energy save time.. but I have a few that never shut the machine off & it still sits there in energy save and the fuser is heating the K drum over night & I would like to be able to shut it down automatically... any ideas? Thanks
    • 23010
    Re: Kyocera M6235cidn... Auto shut off function?
    Make sure that your:
    Sleep Level= Energy Saver
    Sleep Timer= 5min or less
    Energy Saver Recovery Level= Power Saving Recovery
    Power Off Rule= ON
    (pg 8-46 to 8-49 of your Users Guide)
    • copykat93
      • Oct 2021
      • 281
      Thank you sir... As always, YOU ROCK!!!
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1897
        QA_I175_2NR_0049_SB.pdf
        These have worked good for us.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • ntbann
          • Jan 2012
          • 631
          Originally posted by tmaged
          [ATTACH]59177[/ATTACH]
          The dashes still come back with the new drums. BC's suggestion for sleep timers is the way to go.
          • copykat93
            • Oct 2021
            • 281
            Hey Guys, I just set in a New Kyocera M6235cidn at customer on July 27, 2023.... Got a call this morning with the traditional dash marks happening. I get there and the machine has a total page count of 10,700 and of that total- 9,900 is color. the black drum had dash marks all over it from one end to the other, the Magenta had 1 dash mark & the Cyan had 2 dash marks. I was able to polish them all off with a soft cotton cloth & water... The sleep timer was already set to 3 min, I changed it to 2 minutes.. sleep level is set to energy saver, energy save recovery level is set to Power saving recovery... BUT I couldn't find the power off rule... I searched through the menu & couldn't find it. I wanted to set it to ON, but I couldn't find it. I explained to the customer about the heat for the black drum, but it's the first one that I have had that has had the dash marks on the Magenta & Cyan drums. VERY clean environment, machine has plenty of ventilation & all else is super clean.
            • Crusher
              • Jan 2018
              • 17
              This be good one for a sample picture. If dashes you mean like rain dropping all over at random not repeated. It's usually developer and be caused by bad toner or mixing of 2 diffrent toner brands to. I like to replace drum and developers at same size on thses.
