6054ci with DP-7160
  • tech07
    • Aug 2008
    • 410
    6054ci with DP-7160
    OK. I have repaired many early doc feeder series reading wrong paper size by Cleaning/adjusting the small circuit board under the side guides. Today, I ran into a Dp-7160 doing the same. There is no pcb under the side guides. Without thinking, I popped of the side quides top plate and almost never got it back on. Any input on this wrong size detection with these new doc feeders ?
  • Lunatech
    • Oct 2012
    • 216
    Re: 6054ci with DP-7160
    There is an original width sensor in there. If the one you are working on doesn't have one maybe it was left out at the factory.
    • KYO_OEM
      • Aug 2011
      • 726
      Take care for bulletin N077 and follow up page 7/7
      • KYO_OEM
        • Aug 2011
        • 726
        Regarding point 2) from Kyo bulletin page 7/7 here you get better explanation from me.
        • tech07
          • Aug 2008
          • 410
          I'm usually pretty good at locating tech bulletins but not this time. Didn't search with SKEW. Thanks for this. Good stuff. Appreciate this.
