taskalfa 5002
  • Gab
    • Aug 2015
    • 666
    taskalfa 5002
    There are a little background on the copy or print (few fade lines). MAchine has not beed used for 2 months and stored in place that we have temperture variations and now has this problem. I executed drum refresh and image was ok for some copies. any idea how to fix it?
    • 29493
    Re: taskalfa 5002
    OEM toner?
      Re: taskalfa 5002
      Samples would be nice.
      • dalewb74
        • Feb 2018
        • 1125
        Re: taskalfa 5002
        how long was it stored?
        • Gab
          • Aug 2015
          • 666
          Re: taskalfa 5002
          Toner is OEM
          Stored for 2 months
          • Gab
            • Aug 2015
            • 666
            Re: taskalfa 5002
            Here is asample of a print
            • Gab
              • Aug 2015
              • 666
              Re: taskalfa 5002
              I replaced the machine with ah other stored in the same warehouse . In the beginning new machine had the same problem but far better image after 2 days image get worst (i have send an image in earlier post ) . I suspect corona. Can it be something else?
              • Gab
                • Aug 2015
                • 666
                Re: taskalfa 5002
                Also can anybody tell me if ta 5002 and ta35000use the same charge roller
                • copiertec
                  • Jan 2016
                  • 2186
                  Re: taskalfa 5002
                  Totally different charge roller assembly.
                  • copiertec
                    • Jan 2016
                    • 2186
                    Re: taskalfa 5002
                    I have to ask, just like bsm did, is it OEM toner? Because if you issue is bad toner you are barking up the wrong tree at this point and would start there. What direction is the paper running in your example, A3 or A4? Have you removed the drum unit and developing units and visually inspected them? What does your charge roller look like? What does the drum surface look like? Do you see any marks on it from the charge roller sitting on it for months with no temp control?
                      Re: taskalfa 5002
                      I'd start with a new PCR and if that doesn't clear it up, replace the DV unit.
                      • Gab
                        • Aug 2015
                        • 666
                        Re: taskalfa 5002
                        Toner is OEM
                        The dirrection of l;ines are vertical to the direction of paper move
                        charge and drum looks ok
                          • 2621
                          Re: taskalfa 5002
                          Those marks look too far apart to be a small roller like charge or developer and since both machines have been subject to temperature variations I would be looking at the fuser, jam a large piece of paper in there.
                          • Gab
                            • Aug 2015
                            • 666
                            Re: taskalfa 5002
                            Finily i swaped drum unit with a one from an other machine which worked ok but the problem remained. when i sweaped developer unit image was perfect. So the problem is at dev unit. Any idea how to fix it?
                            • KYO_OEM
                              • Aug 2011
                              • 696
                              Re: taskalfa 5002
                              From my technical point of view it must be related to the used toner.
                              In past you changed dv unit and after a short while it came back.
                              Now, with other dv it`s o.k., but i think it will come back if enough "broken" toner would forwarded to this dv.
                              Do you see red mark on the rear side from toner cartridge?
                              Normally it`s hidden, only in case of usage from empty bk cartridge for waste, it becomes red and you can`t mount this cartridge for toner anymore.
                              But i have seen this kind of usage several times.
                              I don`t know how the endcustomer was able to insert the cartridges but it would done
