part number question
  • Scottb
    • Apr 2013
    • 306
    Does anyone know the part number for the grease used on the drum drive shaft?
    • 23003
    Re: part number question
    I checked my crystal ball .... and yes, I still do not know what model that you are referring to. =^..^=
    • PiniuBudyniu
      • May 2023
      • 16
      Im curious too, what type it is. If You're talking about the pink grease.
      • Scottb
        • Apr 2013
        • 306
        this happens to be a 7003, but it appears to be the same grease as a 00 01 02 03 04 from 40 to 80 cpm machines gets on your arm while doing pm's. I had one container, but cant remember where I found the number originally.
          • 23003
          CONDUCTIVE GREASE GE-334C(20G) A0199040
          Genuine Ricoh 52039502 Grease G501
          Genuine Konica Minolta Conductive Grease 00GR00200
          Electrically Conductive Grease | MG Chemicals (847)
          I'd imagine any one of these would serve. Thank you Google! =^..^=
          • FriendlyTech
            • Jan 2018
            • 30
            7bg010009h grease molykote em50lp 50g
            This is the pink grease from Kyocera
            • taskalfaman
              • Nov 2009
              • 137
              dear all,
              Low-resistance contact grease 302LC94790 GREASE FLOIL G-347CA(10G) SP
              have fun
              TM
