Kyocera 3212 Toner not recognized
  • JINACHANDRANS
    • Sep 2019
    • 41
    Dear friends,
    kyocera mita taskalfa 3212 shows "check the Toner Continer", i replaced with new toner(original) cartridge, but
    the problem not solved. it shows same message. i tried with different toner cartridges. i had a service manual
    but i couldn't find any solution for this problem. pl give me the suggestion to solve this problem.
  • dalewb74
    • Feb 2018
    • 1155
    Re: Kyocera 3212 Toner not recognized
    is it a kyocera toner? if not, there lies the problem...
    • JINACHANDRANS
      • Sep 2019
      • 41
      I use only original Toner.
      • Lunatech
        • Oct 2012
        • 208
        I'm not trying to be insulting here, but are you sure it is the correct toner for the TA3212? Meaning is it TK-7127 and not TK-7107? I'm not even sure the TK-7107 would fit into the 3212 but if it does, it would be an easy mistake and I don't know what would happen.
        For what it's worth I hope this helps.
