Kyocera 3252ci - belt cleaning motor and gears
  • kuby
    • Oct 2007
    • 1395
    Is there a parts break down for the DR-8350 (302L793120) drive assy. for the 3252ci. The belt cleaning motor and the 40/21 gear that it drives has some worn teeth. Took motor and gear out of another machine and the customers machine is up and running again. Just would like to order them so I would put the other machine back together. Do you have to order the whole assy.? Seems a waste for just a few little parts.
  • Ropariva
    • 652
    Re: Kyocera 3252ci - belt cleaning motor and gears
    Have had several discussions with Kyo regarding parts like this. The answer is always order the assembly [emoji53]
    Sent from my iPad using Tapatalk
    • kuby
      • Oct 2007
      • 1395
      Yea, that is what I thought.
      • kuby
        • Oct 2007
        • 1395
        Found the gear and a motor.
        wormwheel drive gear - 302K021480
        parts DC motor assy - 302ND94050 (has a different color gear bur thinking it will work)
