Upgrade for TASKalfa 4054ci already initialized
  • clacico
    • Nov 2012
    • 5
    [Misc] Upgrade for TASKalfa 4054ci already initialized
    Hi everyone, is it possible (perhaps via 10871087 or hidden code) to upgrade a TASKalfa 4054ci to the faster 5054ci model?
    The machine has already been turned on and initialized, but the upgrade code has not been entered.
  • KYO_OEM
    • Aug 2011
    • 711
    Re: Upgrade for TASKalfa 4054ci already initialized
    Easy answer: NO!!
    Only 1 time during first start up you are able to terminate the final speed.
    • Samanator
      • Sep 2017
      • 577
      Your company would have to have purchased an Upgrade Kit (UG-38) to generate a License Key. If you did not enter a License Key to upgrade the machine when you first turned it on, then no.
      And you would have known if you had.
      Now I have turned a new machine on and the prompt comes up. I didn't input anything and turned the machine off. I was later able to put in a License Key.
      But if you have the machine up ad going, then the easy answer from KYO_OEM applies.
