TA 356ci ghosting
  • brancas
    • Jul 2009
    • 78
    TA 356ci ghosting
    Hello everyone. As the post says have a 356ci that is ghosting on prints and copies. A MK A kit was changed and the tech assures me that the machine was switched off and unplugged before the kit was installed.Prior to that the machine was in house for a few weeks to correct a grinding noise. The toner supply was replaced for that issue and the machine was returned to the customer fully operational. Updated to latest firmware and replaced drums transfer belt and fuser. Tried different media types as well but no success. Any other suggestions?doc00001920231218185602_rotated.pdf
  • KYO_OEM
    • Aug 2011
    • 710
    Re: TA 356ci ghosting
    Ghosting from all colors or only one?
    Toner?
    Status Page shows usage from not recognized toner for cyan.
    • copiertec
      • Jan 2016
      • 2192
      OEM or third party aftermarket toners? Your cyan is not even showing up on the toner gauge.
      • brancas
        • Jul 2009
        • 78
        Toner?
        All colors. Cyan toner is finished. Original toners
        • KYO_OEM
          • Aug 2011
          • 710
          with ghosting in margin areas or not?
          • brancas
            • Jul 2009
            • 78
            yes in the margin area and the bottom half of the page
            • KYO_OEM
              • Aug 2011
              • 710
              looks like fuser controlling problem if tech mounted a new one, or wrong media type settings. (weight wrong)
              Did tech checked image before fuser?
              Do you have U000 for analysing?
