U906 failing through KFS?
  • copytech_32716
    • Nov 2022
    • 21
    Anyone else?
    Been happening for a few weeks. It gets to the end and then says timed out.
  • jcg54
    • Jul 2023
    • 49
    Re: U906 failing through KFS?
    And you've updated firmware? When I get a machine being tempermental with KFS I need to update firmware, Sometimes at the machine itself.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 726
      Originally posted by copytech_32716
      Anyone else?
      Is this multiple machines, different customers, or is it the same customer, same location, etc?
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1901
        I'm seeing the same thing. Multiple customers/models/locations
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • KyoServiceManager
          • Oct 2017
          • 30
          I believe there was a remedy to this issue in the latest update.
          "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
          • tmaged
            • Oct 2008
            • 1901
            I spoke with Jeff @ Kyocera this morning. They have a ticket open with Japan regarding the issue.
            Hope that helps !
            -Tony
            www.dtios.com
            • JVergin
              Service Tech / IT Rep
              • 216
              I had the same thing happen once, but it did seem to actually perform the U906 even though it claims the action timed out. Took quite a while before the copier became visible through KFS again.
