Kyocera MA2000W USB or WiFi printing does not wake up the printer from sleep mode
  • brunot
    • May 2012
    • 148
    [Misc] Kyocera MA2000W USB or WiFi printing does not wake up the printer from sleep mode
    When you send a print job to the printer, it remains asleep until you press any key to turn it back on for printing.
    I cannot disable sleep mode, and the default setting is 1 minute.
    I would like to try a firmware update, but I cannot find the firmware on the Kyocera support link.
    Does anyone have this model? If so, do you have this problem?
    Thanks in advance.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Kyocera MA2000W USB or WiFi printing does not wake up the printer from sleep mode
    On other models, the fix is to set the sleep level from Energy Saver to Quick Recovery. This keeps the NIC from shutting down.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • dalewb74
      • Feb 2018
      • 1157
      are you using the kyocera print driver? or the generic windows junk print driver?
