6052ci Bypass paper size error
  • carolscurriculum
    • May 2017
    • 39
    I am getting a error in the MP tray I will scan a letter size sheet it will print a few copies then it says to add correct paper even though the letter size is in there already it does it from scan and print.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1897
    Re: 6052ci Bypass paper size error
    The display tells you what media type and size it's looking for.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • carolscurriculum
      • May 2017
      • 39
      No kidding I know that. The problem is that it is looking for the size that is already there.
      • carolscurriculum
        • May 2017
        • 39
        I believe I figured it out. It seems like it jumped a cog on the gear that is for the paper size sensor assembly as it was showing 12 x 18 when I had 11 x 17 in it. I was able to get it realigned so it reads correctly.
        • Lunatech
          • Oct 2012
          • 215
          Good job.
