Utax 5007ci streated prints with lack of cyan
  • avio2
    • Jul 2010
    • 150
    replaced dv and dk and carried out the
    calibrations, the machine runs for a few days and the defect reappears
    run U132 and calibrate again, the printouts return decent and rewind
    not have a code error and check hopper motor is ok
    i hope a hopper h defect?
    toner katun
  • Larhal
    • 564
    Re: Utax 5007ci streated prints with lack of cyan
    Try Stopping the print and check the transfer belt or swap a known good transfer belt and test with that.
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 680
      If you have one of those microscopes that shows individual color dots, I would see what colors are being laid down. My thought is transfer unit, however I would also run U087 prints to show the individual colors.
      Had a similar issue with a 5002i with spotty areas, and it needed the transfer unit values reset with U469 that someone didn't do after transfer unit replacement.
