Need Kyocera 3051Ci Charts for Adjustment Please help.
  • Mostafa Mostafa
    • 27
    I need Kyocera 3051Ci DP Charts for Adjustment Please help.
    At least PDF Good Quality so I can print and use
    1- P.N 7505000005
    2- P.N 303JX57020
    3- P.N 303JX57010
    Thanks in Advance
  • Ropariva
    • Mar 2016
    • 661
    Re: Need Kyocera 3051Ci Charts for Adjustment Please help.
    Is it the colour reproduction you need to adjust or image position from ADF?
    All image position adjustments can be done manually and using auto adjust in U411 the machine spits out the test chart
    Sent from my iPad using Tapatalk
    • Saturn
      • Nov 2023
      • 171
      The adjustment will not work correctly with laser-printed PDF files. You need to have the original, offset-printed charts.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • Mostafa Mostafa
        • 27
        the main problem is that I locked color in this machine so I can not reproduct manually , Also I did initialize all memory with U20 so My machine do not run properly but I need to adjust adf to get right scanned image and print a black color image in real shape same as original on my pc.
        Please help me I am on third world country so I can not afford to buy kyocera charts.
        • Mostafa Mostafa
          • 27
          at least a nearly true color image with pdf adjustment , I appreciate what you do guys in here. Thanks.
          • Ropariva
            • Mar 2016
            • 661
            • Mostafa Mostafa
              • 27
              I meant U20 Secret intialization for all memory .
              "U20"
              U469 and U410 Requires Color which is not available beacuse my Machine is flipped into one color only "Black" !! But I need to use its scanner for scanning through smb and adjust the main scanner for copy and gamma and rest of image details which I cannot do while machine in mono mode !!
              • Ropariva
                • Mar 2016
                • 661
                  • 883
                  [QUOTE=Mostafa Mostafa;2584510]I meant U20 Secret intialization for all memory .
                  "U20"
                  Is the default set to black in the default settings . You cant switch to color
                  • Mostafa Mostafa
                    • 27
                    nope , there is no vodoo custom firmware , but there is a secret engineer firmware Which use "06141010" to get into Service which include only panel with hidden secret codes such as U20 and custom wallpaper change for corporations etc. Reset all counters in the machine etc... , if you can help me with scanned Charts, I would appreciate that. thanks
                    • Mostafa Mostafa
                      • 27
                      there is no dev tanks or drums in the machine only B DEV & drum . so I can not use U411 , U469. help guys with charts wont harm to reach out a hand each other .
                      • Ropariva
                        • Mar 2016
                        • 661
                        • KYO_OEM
                          • Aug 2011
                          • 710
                          • Mostafa Mostafa
                            • 27
                            BY THE WAY : I managed to fix my problem via using Adobe photoshop to cut the chart form service manual and magnifing it 8000 % to print it out and use it as a reference and fix my problem.
                            don't judge me cuz none without mistakes beside I knew there were consequences of damaging dp scanner but I had to do it cuz I was in condition of U465 telling me that laser power is low and affecting image contrast and faint print which is not according to drum & Dev & laser sensing of confused machine .
                            Also based on this values, system calculate mc charge, dv charge, transfer charge, laser power and so on.
                            Also getting judged according to counter which is useless to get you in consumption circuit to feed the company
                            I fix machines since 1998 with low tools and just thought so please be gentle.
                            in other words I can easily just get another dp to switch firmware chip to fix the whole thing then get it back.
                            thanks for beeing useless and judging.
                            • KYO_OEM
                              • Aug 2011
                              • 710
                              I think now it`s running for the moment, but with wrong values!
                              Bases on my experience: you will get other problems in future.
                              U465 values are depended to U119 and U412
                              If you print U412 with wrong U10x data you get the next big problems.
                              Good Luck
