4501i Time for maintenance (T)
  • copydocinc
    • Mar 2015
    • 263
    Screen says time for maintenance (T)
    I cannot clear it through normal means, meaning sims 127, 167, 251, 930
    maintenance preset counters are set to normal numbers
    clock and date are set to correct dates and delivery date too.
    I figured the (T) means Transfer, but transfer belt numbers are reset too
    Any tricks I'm missing here?
    • 23010
    Re: 4501i Time for maintenance (T)
    LOL! I haven't seen that in ages!
    The installation date has not been set (or has been cleared). Set installation date in U278. Run U906 Partial Reset. =^..^=
    • copier tech
      • 8220
      There was also a firmware fix for this message if I recall.
      • still
        • Sep 2012
        • 8
        You can try going into maintenance mode. Code 251 clear maintenance counter
        • darry1322
          • Oct 2010
          • 817
          Not for "Time for Maintenance T"
          As the others have said, Update firmware, set delivery date, run 906.
