taskalfa 3500i
  • Gab
    • Aug 2015
    • 671
    taskalfa 3500i
    paper cassete stuck about 10 inches out and it can close. Customer said it opened cassete to fill paper and then it doesn;t close. I checked rails etc and looks ok. Any idea?
    • 900
    Re: taskalfa 3500i
    Not sure if that is the model that has the retard roller holder that breaks on the feed unit .
    • dalewb74
      • Feb 2018
      • 1157
      Re: taskalfa 3500i
      did you pull it completely out and look behind it?
        • 23009
        Re: taskalfa 3500i
        Most often, a piece of plastic breaks out of the rail on the right or left of the paper tray (ON the paper tray, not in the the machine). It's usually because somebody leaned on it while it was pulled out. I attempted to epoxy one tray, and it held for a while, but I think this is a behavior that customers tend to repeat. =^..^=
