Hi all.
Were having some problems setting up the Fax on a Taskalfa prior to sending the copier out to the customer. We unbox the copier place it on a pedestal / paper feeder and fit the doc feeder. We then run U410 (density adjustment) then test the copier.
Firmware update TASKalfa250ci_300ci_400ci_500ci_02.00.0040 is usually required as mentioned in the fax instructions.
In some cases the fax works but on other occasions we get a C0650 which is "FAX image DIMM problem check improper DIMM is installed".
On one occasion we had a Taskalfa 400ci which had a fax fitted and tested but for some reason was cancelled by the customer. We needed to get a Taskalfa 250ci to another customer and I was asked to remove the fax from the 400 and fit it to the 250. The fax didnt work in the 250 giving the C650 error described above, both machines had the firmware update. I fitted the fax back into the 400ci and it worked..
If my memory serves me right on the earlier Kyocera products there was a service mode clear and a country select you had to do after fitting the fax. There doesnt seem to be anything like this for the Taskalfa fax.
