Kyocera KM C3232E Z Folding copies
  • waynechurchill
    • 15
    I have a Kyocera KM C3232E with tray option PF-710 (500 sheet tray3 & 4) which z fold almost all copies from tray 3 & 4 (A3 & A4) then sometimes causing jams at the exit. I have replace the option PF710, but it still does it. Trays 1 & 2 work fine without any problems. So i've figured that rules out any of the clutches & soleniods (which i checked any how in the maintenance mode out of desparation). I've just been rereading the service manual and have noticed U051, if i adjust this, firstly can i use this for tray 3 & 4?? and do you adjust the trays separately or secondly if it''s a single adjustment (large & small) will i then have problems from trays 1 & 2??
    If somebody could please give me some idea i will be extemely grateful!
    Wayne
    • 23010
    U051 will not solve your problem. This sim adjusts the paper buckle at the registration roller only. The adjustments affect all cassettes equally. So if you change U051, most likely trays #1 & #2 will start to jam or Z-fold, and trays #2 & #3 will not be improved.
    Personally I would look at the pressure springs behind the idler rollers in the left door. They came from the factory with one spring per shaft. I began adding a spring for two springs per shaft. Then I found out that the replacement springs are modified to be stronger.
    Also look at the motor and clutches driving the vertical path rollers. I've seen the plastic C-clips chewed up, and fallen off in the bottom of the machine, usually accompanied by a nasty scraping noise during feeding.
    What jam codes? J12, J19, J24?
    • waynechurchill
      • 15
      Thanks for the quick reply
      I'm not getting any nasty noises, the printer sounds just how it should. If i print one copy it tends to get z folded, if i print several, about the 3rd print will get crunched up just before the registration (the point that causes the z folding). The jams are J-18, a few at J-31.
      The springs you mentioned is the part number 302FZ22341 and wouldn't this affect prints from trays 1 & 2??
      • vikingmita
        • Nov 2008
        • 163
        switches ok? a quick check on rollersprings is to run the machine as you push the sidedoor in. my guess is faulty switch
          • 23010
          The part # I've been using is 302FZ04763.
          Theoretically, yes, these springs could affect prints from all sources. But not necessarily. It could be a switch problem, but I haven't seen any of those yet.
          Let us know what you find. =^..^=
          • waynechurchill
            • 15
            Today i've checked the pressure springs, they all seem ok (even tried printing with the finisher removed and putting pressure on the left doors and compared to a similar printer unfortunately not the same as i would have swapped parts around). Checked the switches again in U31 all ok and as Black cat stated U051 does nothing, which makes me admit there must be a hardware fault and not just a system setting. So out of pure desperation i'm thinking of ordering the feed drive assembly 302FZ93261 as i cannot for the life of me see a problem with any of the feed units. Has anybody got any other ideas????? or should i just start replacing parts? (something i don't like doing if i'm just guessing)
            Wayne
              • 23010
              If I was you, I would dig into the mechanics of the vertical path and make sure everything is turning when it should. =^..^=
              • ron c
                bulletin
                check bullletin SB-8433 for left door modification
                • waynechurchill
                  • 15
                  Hi Ron
                  Is there any chance you could forward the bulletin or give me some insight. I would be extremely grateful.
                  Wayne
                  • ron c
                    bulletin
                    Part# 302FZ93313 cover feed lower assembly,pn#302FZ04763springs (4),pn#302JD22010 film.order these parts to fix J-18 problem,it's the lower door assembly.what happens is the finisher pulls at the door for so long and the door can get warped,so adjust your finisher as well.If this does not fix issue than it's the clutch/gear pack in back of copier.but you can find this the kyocera web site
                    • irtek
                      • Jun 2009
                      • 112
                      In my experience Z folds are usally caused by a clutch overdriving. Most of the time it happens at the reg. rollers, but it is not the reg. clutch causing the problem, it is the pre reg clutch not stopping when it should. Usally replacing the pre reg. clutch solves the problem.
                      • waynechurchill
                        • 15
                        I've ordered 302FZ93281 the drive feed assembly because i think it's a clutch causing the problem. I'm hoping that by replacing the whole unit it will cure the fault, i'll find out during the week and will update.
                        • waynechurchill
                          • 15
                          The problem was caused by the feed clutch! All fixed
