I have a Kyocera KM C3232E with tray option PF-710 (500 sheet tray3 & 4) which z fold almost all copies from tray 3 & 4 (A3 & A4) then sometimes causing jams at the exit. I have replace the option PF710, but it still does it. Trays 1 & 2 work fine without any problems. So i've figured that rules out any of the clutches & soleniods (which i checked any how in the maintenance mode out of desparation). I've just been rereading the service manual and have noticed U051, if i adjust this, firstly can i use this for tray 3 & 4?? and do you adjust the trays separately or secondly if it''s a single adjustment (large & small) will i then have problems from trays 1 & 2??
If somebody could please give me some idea i will be extemely grateful!
Wayne
Wayne
