km 2550 C0210
  • Mark B
    • Jul 2006
    • 153
    km 2550 C0210
    I had a tech flash a machine and now it has a c0210 code and will not reset. I tried flashing with a new card the machine takes the flash, but the code is still there. Has anyone seen this?
  • gpoffmachs
    techie
    • Feb 2005
    • 55
    replace the rom or per manual main pcb or printer board. i would start with the one he flashed. most likely a corrupt flash
    Techie
      • 23010
      I'd have to agree gpoffmachs. I've killed a few machines (or Eeproms specifically) just doing the flash. The same CF card has worked before & since. I can't explain it, it just happens.
      I think I'd start with the Engine DIMM. It sure would help to know which part of the flash errored out. Then you'd know exactly which Eeprom to replace. It tells you right on the screen (if you look).
