KM3060 error code not in service manual!!!!
  • pete!
    • 10
    KM3060 gave error code 9400
    does anyone know what is it ....
    I cheched the service manual and it not even there
    we reboot the copier couple of time ..and now gone...
    if anyone know....before it does come back...
    lmk asap!!
  • cboucher
    • Aug 2025
    When I get unpublished codes on Kyocera machines the first thing I do is update firmware to latest level. If it already is at the latest level, I'll flash it again, just in case it got corrupted.
    Good luck...
    • Craigdumass
      • Jun 2009
      • 61
      Not sure what it is a good rule of thumb to remember on most Kyocera Boxes
      Codes that start with 0 are usually logic
      1's are usually lift motors
      2s are drive problems
      3s are scanner
      4s are laser
      5s are main charge
      6s are fuser
      7s are toner and Developer
      8s are sorter related
      9s are Document feeders
      Not always true but that is the way I remember them in my head.
        • 23009
        If you're sure about the C9400, I'd have to agree with Craigdumass. The simple thing to do is power off, unplug the document processor, then power up. My bet is that your code will be gone.
        Most of the DP codes are communication related, so if your code disappears, I'd look at the firmware first, then the pigtail from the DP to the machine, the DP controller, and the main PWB (in that order). =^..^=
