FYI KM 8030/6030 Exit Jams
  • Raymondd
    • Jan 2008
    • 108
    I have had 2 8030s in the last month give jamming issues here is the cause...Mainly jam 81. The pic is terrible maybe I can explain
    The metal plate that is circled has a small piece of sponge I guess for noise reduction, well the sponge deteriorates after time but the glue doesn't.
    The solenoid isn't strong enough to open the exit guide.
    Clean the glue off problem solved.
    Hope this helps!
    Ray
    • 23009
    I'll keep my eyes open for that one. Thanks Raymondd.
    • Hose1cook
      Defective Technician
      • Jun 2008
      • 80
      There is a QA on this, they changed the material the pad is made from, I've changed the pads on all my machines.
      • academy1st
        Re: FYI KM 8030/6030 Exit Jams
        This just saved me a lot of time and frustration. Thank you so much!
