Insane copy quality problem, not hardware - Sample Included
  • dyodyo
    • 28
    #16
    Originally posted by JasonW
    ...I have replaced the fuser rollers, charge wire assembly, transfer roller, developer unit, and tested three different drums. All show the exact same problem.
    he already replaced this parts, definitely its not from the charger nor the drum unit. you dont need to perform drum refresh if drum unit already been replaced. most likely high voltage board(contact is not good).
    keep us up to date with this prob jasonW! good luck buddy!
      • 30340
      #17
      dude
      bad laser will give you dots
      LOL
      • 10871087
        • Jan 2005
        • 1062
        #18
        ...The only things it could possibly be are Fuser, Drum, Charge, Developer, & Transfer roller right?...
        You have a bad Laser Unit.
          • 23009
          #19
          How interesting! I don't think anyone has suggested the paper feed tires yet.
          Let us know what you find. =^..^=
          • n25an
            • Jul 2008
            • 1030
            #20
            another possibility
            might be this... near the drum on some of these older copiers there is red felt roller... you will see it when you pull out the drum... directly in front of that or rather above it a white bar and in front of that and slightly above is a metal bar... in some models... there is a special cleaning blade that attaches to that... if this cleaning blade gets worn... it can cause this issue... the blade usually comes in the drum kit if I am not mistaken... I had a similar problem a while back... changed drum, fuser, developer and only after calling up the area tech did I find out that this guy can cause issues... if he goes bad... toner spills... on the drum and then goes everywhere... causing nasty ghastly stuff... the hint will be if the red felt is black... if its white thats also not a good sign... but black says the blade is getting bad...
            Sad To Say I Don't Have a Life
            I do this stuff on the weekends too
            • copytechman
              • Nov 2008
              • 947
              #21
              Should be quite interesting to hear what resolves it considering the wide variance of responses!
              Regards!
              A.
              • JasonW
                • 52
                #22
                FIXED!!!!!!!!!!!
                Was the stupid drum after all. The two used drums I tested had the same similar problem. Of all the luck...
                Thank you everyone so much for the help. Your support is priceless
                  • 30340
                  #23
                  fixed ?
                  maybe?
                  • dyodyo
                    • 28
                    #24
                    of all the luck in the world buddy! both drums you tested has the same prob and coincidently same image?!
                    hmmmmh.... tell your shop head to throw all those stupid used drums and other used stuffs so atleast it may not add up to the trouble when repairing the machine.
                    • 10871087
                      • Jan 2005
                      • 1062
                      #25
                      Well it looks like I was wrong, I guess there IS a first time for everything.
                      • IKy
                        • 19
                        #26
                        it's common for those copiers, working in bad condition (dirt, humidity). You can see those dots on the surface of drum(when you have this problem), just pay attention
                        • n25an
                          • Jul 2008
                          • 1030
                          #27
                          a word on parts
                          my understanding is that all parts for the km 4030/35 models are refurbished... especially drums... I have had drums in maintenance kits that were just as bad as the drums I was replacing... on numerous occasions... wondering... is there a way to recondition the drums besides the drum refresh...????
                          • IKy
                            • 19
                            #28
                            no ways, drum refresh helps sometime a bit, but just for while
                            • copygal
                              • Feb 2012
                              • 23
                              #29
                              Re: Insane copy quality problem, not hardware - Sample Included
                              check the main charge grid. may be loose.
                              • DWise
                                • 895
                                #30
                                Hey copygal... you're about 3.5 years late on the response. He replaced the drum and it resolved the issue.
                                Do for one what you wished you could do for everyone. - Andy Stanley
