Taskalpha 500 cyan issue
  • LNorris
    • Sep 2008
    • 645
    has anyone ran across a cyan streaking issue?
    i have replaced drum/developer and even swapped out transfer belt. still there, replaced the hvpwb per tech rep and that didnt clear it up. the streaking is not consistant and the coverage varies. it happens from an internal print or off the optics.
    i'll try to attach a copy of the problem.
    • 22999
    I have not seen this problem on the Saturn, but from the looks of your sample scan I also would lean toward a high voltage issue, probably primary charge.
    So you've replaced the Cyan drum, Cyan developing unit, and HV PWB... The only remaining HV components are the connectors/cables/HV leads/HV contacts, possibly drum ground issue?
    • LNorris
      • Sep 2008
      • 645
      thanks. i'm checking all contact points at this time. trying to see what is and isnt making contact. so far all looks good, but nothing is noticable at this time.
      i'll let you know what i find (when i find it).
      • LNorris
        • Sep 2008
        • 645
        well, the tech rep and i have been working on this all day. the drum/dev/transfer belt, and hvpwb have been replaced. still had the issue. we finally went into sim mode 100 and changed roller2 to -128 (negative 128). to clear it, but the image is ghosting and colors are off some when mixing with cyan. i kept dropping it down, but around -100 the cyan goes back to streaking.
        so we are gonna hit it again tomorrow (maybe literally..lol)
          • 22999
          If you've got the tech rep there, I'm assuming that the machine is at firmware v. 6.0/1.07. Just for kicks, I'd try downgrading the firmware to 5.0
          • n25an
            • Jul 2008
            • 1030
            quick dumb question
            I also assume you replaced the transfer rollers...
            Sad To Say I Don't Have a Life
            I do this stuff on the weekends too
            • Jimbo1
              • Mar 2008
              • 845
              Is the tech rep Tom"Damn"General??
              "Some days you get the bear, some days the bear gets you."
              Cdr. William Riker
              • LNorris
                • Sep 2008
                • 645
                yes it is Tom..lol
                we found the problem late this afternoon...whew
                i'm still tweaking things to determine exact issue, but it is narrowed down.
                we replaced main pwb, engine pwb, main power board, hvcpwb and still had issue. we finally swapped the pcbs on the front of the machine where the dev and drum plug in, and replaced the bezel. it cleared up!!! the old bezel still shows some cyan streaking. so i've got to get some conductive grease and try that on the bezal to see if that improves it on the old bezel.
                lots of headaches working on this...i'm about to throw it out in the street..lol
                • n25an
                  • Jul 2008
                  • 1030
                  question
                  do you think the board died because of weather or it got fried from a power surge???
                  • LNorris
                    • Sep 2008
                    • 645
                    we dont think it was power related. the grease on the bezel is pretty much gone and thinking the drum wasnt/isnt getting good ground. it may have affected the boards somewhat.
                    the machine has over 512k on it, i put a new bezel on it and it cleared up.
                      • 22999
                      Thanks for posting your results. I'll watch for that one.
